586,103 active members*
3,234 visitors online*
Results 1 to 6 of 6
    Oct 2012
    28
    Thin wall parts to laser cut
    Hi, It's really about material choice I'm asking for advice about.
    As per the attached picture, I had this cut in the UK for £50 quid. Now as a prototype of 2pcs of 3mm cast acrylic sandwiched together to get me 6mm thickness required, I understand the low volume - high cost of parts, its all in the setup which equals time.
    The problem I have is, I would like to make maybe 40 or 50 sets of these things, for a custom bit of arty display electronics I'm woking on for myself. The cost of that would be prohibitive and given the slight warpage seen, I may not get CNC / laser cut accuracy expected due to the slight material deformation.
    Is there a material or process (not EDM ££££££) which could stay dimensionally stable while being lasered, but only have 1mm walls?
    These could be made from anything, and the dimensions of the piece are 105 x 78mm and as stated minimum but consistent wall thickness is 1mm.
    Any suggestions?
    Many thanks
    Andy
    Attachment 479954
    Feb 2022
    20
    Re: Thin wall parts to laser cut
    I will try that on a piece if this tonight
    https://www.gravostoreusa.com/eng/product/18993
    Does it need to be see through?
    That material comes in 2 or 3 layers
    Sent from my SM-G988U using Tapatalk
    Oct 2012
    28
    Thanks, No, material transparency (or lack of) is not a concern.
    Oct 2012
    28
    I attach the dxf for ease and clarity...
    Attached Files Attached Files
    Feb 2022
    20
    Sorry I can't help
    I do not have access to a dxf file
    Dec 2006
    124
    The material Delrin is used for its dimensional stability. It is a polymer material. I have seen a number of laser shops make parts from it.
    "Polyoxymethylene (POM), more commonly known as acetal or its branded name Delrin®, is an engineering plastic offering low friction, high stiffness, and excellent dimensional stability."
    - - - Updated - - -
  1. Holding thin wall round parts without deforming in a mill
    By DerekSSS in forum MetalWork Discussion
    Last Post: 05-01-2016, 08:41 PM
  2. What is the best way to cut thin wall brass tubing?
    By lerman in forum MetalWork Discussion
    Last Post: 08-11-2015, 03:47 AM
  3. Laser cut thin carbon fiber
    By rcpilot82 in forum Engraving Machines
    Last Post: 09-24-2010, 01:03 PM
  4. ring roll forge for thin wall parts, 1" to 4" OD
    By Arnaudb in forum Bending, Forging, Extrusion...
    Last Post: 04-23-2008, 11:01 AM
