586,106 active members*
2,918 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Help needed for best DIY controller box for mach 3
Results 1 to 2 of 2
    May 2022
    I wish to replace controller for
    PROXXON - FF 500/BL-CNC
    with a new system that will allow use of mach 3. The controller at the moment only supports NCCAD which is a nightmare to use with strange g code requirements. So wish to scrap controller and software.
    What is the best off the shelf kit? It must have opto couplers to isolate pc. I have a uc100 parallel adaptor for mach 3 also.
    Also mach 3 on laptop.
    Put of touch and wondering if anyone can help with best places to buy or best hardware?
    Any help, even if someone has a secondhand system that could be useful .
    Sincerely Mark
    Jun 2005
    1730
    Re: Help needed for best DIY controller box for mach 3
    If you already have a license for Mach3 you can still use that with a cheap USB-MACH3 controller on ebay for about $25 USD. Many of those controller do come with Opto couplers. The other advantage is you do not need a parallel port. If you are running newer windows from Windows 7 or newer this becomes a requirement. Windows 7 and newer will not support the parallel port driver from Mach3 and they will never release a newer version. You could use Windows 7 the 32-bit version if you want to use the parallel port.
  1. mach 4 and x box controller
    By ts1502 in forum Mach 4
    Last Post: 12-27-2018, 09:47 PM
  2. Step2Mach - DIY ethernet motion controller for Mach
    By jarekk in forum Mach Software (ArtSoft software)
    Last Post: 02-13-2017, 09:48 AM
  3. Supermax YCM40 (1986) Anilam controller box, circuit boards needed!
    By metaldirtart in forum Want To Buy...Need help!
    Last Post: 01-20-2016, 07:57 PM
  4. Syil c6 cnc controller box needed!!
    By gglynn81 in forum Syil Products
    Last Post: 09-19-2008, 12:29 AM
  5. DIY-CNC Help needed with Techno-Isel Controller
    By jlettman in forum DIY CNC Router Table Machines
    Last Post: 01-16-2008, 05:56 AM
