586,043 active members*
3,643 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Ae-200 vfd problem mach3 rpm doesn't match with vfd
    Dec 2021
    54
    My vfd is Ae-200 it runs on 12v. I plugged it on 10v and run and trying to do some setting. After that I plug it back to 12v factory setting. After that my vfd rpm doesn't match with mach3. I am sending pictures of mach3 vfd and also manual of vfd.
    Any help will be highly appreciated
    Attached Thumbnails Attached Thumbnails 20220520_203939.jpg   20220520_203945.jpg
    Attached Files Attached Files
    15362
    Re: Ae-200 vfd problem mach3 rpm doesn't match with vfd
    Quote Originally Posted by Chmfhm View Post
    If your Breakout Board requires 12v that would be normal, the PWM to Analog spindle speed control can only be 0-10v
    Mactec54
  1. Replies: 8
    Last Post: 01-07-2022, 05:51 PM
  2. vfd mach3 problem
    By koendersav in forum Spindles / VFD
    Last Post: 10-28-2020, 01:05 AM
  3. Can't control VFD RPM, with Mach3
    By SceroGuitars in forum Avid CNC
    Last Post: 07-12-2018, 06:02 PM
  4. Axis travel (physically measured) doesn't match Mach3
    By neeboy in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2012, 12:36 AM
  5. Need to match VFD to HSD Spindle?
    By firstyear in forum CNC Machine Related Electronics
    Last Post: 09-08-2011, 03:36 PM
