586,070 active members*
3,543 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Panasonic MSD AC Servo - anyone ever fitted/setup one manual driving me insane.HELP
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    15362
    Re: Panasonic MSD AC Servo - anyone ever fitted/setup one manual driving me insane.HE
    Quote Originally Posted by nemo1966 View Post
    I don't understand... CNCnan said "Year the electronic gearing always needs to be checked in the drivers and there are four parameters for that function in two different areas depending on the mode the drive is operated"
    Then you say nothing can be done about torque, I thought that's what gearing did??? Give more torque, if not then why have electronic gearing?
    thanks again
    This type of electronic Gearing has nothing to do with Torque control, this is just a Electronic ratio between the Encoder PPR and the input pulses from the control
    There is servo motor Torque that can be adjusted, normally this is set at the motor specs, there are Parameters that can be adjusted, this is normal for Servo Drives most of these Torque setting do not work when using Position control mode, only when being controlled by +/-10v, for normal use these Torque settings are by default at 100%
    So, if you need more Torque for your machines cutting then you either need a larger Servo Motor or use more mechanical gearing
    Mactec54
  2. #22
    Jul 2013
    16
    I see - thank you for the clarification (everyone).
    Out of interest, do you know what do the "Numerator/Denominator of pulse frequency" and the "Numerator/Denominator of pulse frequency division" are and their relationship to each other???
    thanks again, this thead has turned a nightmare conversion into a breeze
  3. #23
    15362
    Out of interest, do you know what do the "Numerator/Denominator of pulse frequency" and the "of pulse frequency division" are and their relationship to each other???
    Your manual should explain both settings, I have attached a snip I put together that may help a little as there is much more than this to Electronic Gearing
    The Electronic Gear Ratio (Numerator)=Encoder Resolution
    The Electronic Gear Ratio (Denominator)= Travel distance per shaft Revolution
    Attached Files Attached Files
    Mactec54
  4. #24
    Jul 2013
    16
    The manual is written in pigeon English (at best) and doesn't explain what the two items are. I think it expects you to already know.
    thanks for the info
Page 2 of 2 12
  1. Replies: 5
    Last Post: 04-15-2023, 04:46 AM
  2. Home switches in EMC2...DRIVING ME INSANE
    By neity in forum Benchtop Machines
    Last Post: 06-21-2012, 06:20 AM
  3. Gain adgustment with oscilloscope (MSD Panasonic servodriver)
    By Nikomas in forum Servo Motors / Drives
    Last Post: 05-21-2011, 03:07 AM
  4. I need datashhet for Panasonic MSD***
    By Nikomas in forum CNC Machine Related Electronics
    Last Post: 01-07-2011, 09:45 PM
