586,058 active members*
4,101 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VMC15XT Spindle alignment
    Feb 2014
    227
    I replaced motor and spindle and now trying to align the belt. I have the one GTR belt. Going forward the belt rides right in the middle of the pulley and won't move. when I go into reverse the belt starts to walk down to the bottom of the pulley. Any idea why the belt will not move from center going forward but in reverse the belt goes to bottom of pulley? Any help would be great.
    Mar 2009
    1982
    Re: VMC15XT Spindle alignment
    check with sensitive indicator. Axes are not in parallel.
    Feb 2014
    227
    Quote Originally Posted by Algirdas View Post
    That sounds like a great idea thought of that but not sure where to mount the mag base and where to take the measurement from. Any suggestions of how to do that? Fadal has nothing in the manuals of how to go about this!
    Feb 2014
    227
    Quote Originally Posted by ballistic42 View Post
    Problem fixed. I did not have the pulleys set at the correct height per the maintenance manual. A member sent me the picture of the correct information to set the heights. The pulleys are aligned the right way now and no problems. Shout out to Skinner!
    Jeff
  1. SPINDLE ALIGNMENT
    By kevinsmachine in forum Haas Lathes
    Last Post: 08-05-2015, 05:54 PM
  2. Spindle alignment
    By hmc710 in forum Colchester Tornado lathes
    Last Post: 06-07-2011, 12:23 PM
  3. Spindle alignment
    By fastpcuser in forum Momus Design CNC plans
    Last Post: 05-27-2011, 03:15 PM
  4. Spindle Alignment
    By forrest39 in forum Benchtop Machines
    Last Post: 08-03-2010, 11:36 PM
  5. VMC15XT spindle
    By jean-Claude in forum Fadal
    Last Post: 01-07-2010, 07:49 PM
