586,104 active members*
3,385 visitors online*
    Apr 2020
    14
    Parking spindle after job
    I have a homebuilt PrintNC using UCCNC that I mill sheet aluminum with and I'd like to have the spindle park in a certain spot after running a job to facilitate material change. While I built this machine myself, I lack knowledge in the coding. Would I do this in UCCNC or in the post processor of my CAM program? I use Cam Bam and Vectric software for my CAD/CAM. Thanks for any help!
    Mike
    15362
    Re: Parking spindle after job
    Quote Originally Posted by mchesney1 View Post
    Mike
    Depends on how you want to do it, you can add it at the end of every program
    In your program the last Z axis move, send your Z axis to where you what it to be above the part
    G0Z------( This will be where you want the spindle to move to)
    G53X-------Y-------- (This can be anywhere you want your machine to go, either a negative or positive move
    Mactec54
    Apr 2020
    14
    Is there a way to do that in the PP so it would add it each time I generate code? I make a bunch of different access panels for experimental aircraft so each operation is a different batch of products that I nest and then generate the G-code for that run. Thank you for the suggestion either way!
    15362
    If your PP can be changed then yes that is where you can do part of it, the Z axis move you can do that in your cam program as you make the program
    You also have a button on your control that you can send it to park so you can set this up also and just press the park button at the end of your program, to park the machine where you want it
    Mactec54
    Just setup Park 1 or Park 2 in the UCCNC profile to send it where you want it.
    It's super easy. You find the profile folder and edit the correct macro, I forget what number it is, but you simply set the coordinates (in machine coordinates) and it will go there once you press the button. For example I use Park 1 to offset the table to make it easy to load my vise. No coding required.
  1. Biesse Parking Position Code
    By oferyaar in forum WoodWorking Topics
    Last Post: 04-16-2019, 09:25 AM
  2. Parking the lower turret
    By Dan B in forum Esprit
    Last Post: 01-25-2013, 08:12 PM
  3. Parking gone HiTech
    By Al_The_Man in forum Community Club House
    Last Post: 05-24-2012, 04:09 PM
  4. Parking a bed mill that in not under power
    By zoeper in forum Uncategorised MetalWorking Machines
    Last Post: 04-12-2012, 08:06 PM
  5. parking problems
    By N.V.M. in forum CNC Machining Centers
    Last Post: 07-27-2007, 05:04 AM
