586,551 active members*
3,269 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco VMX30 bad HDD
Results 1 to 9 of 9
    Sep 2009
    8
    Hurco VMX30 bad HDD
    Hi all,
    I have problem my VMX30 (full Yaskawa drive and 2.37.03e (Patch D) version).
    The error is as follows:
    HDD was ruined and data backup was not about it. Refilling the data of another VMX30, but I get the next error message when I start the reference point.
    "Schleppfehler Der Achsen 4"
    If I connect axle 4 to the controller, I get the following error message:
    "Schleppfehler Der Achsen 16"
    Does anyone know the solution? To a parameter error...
    Could anyone send you image files from 2.37 installation disks?
    Sorry my bad englis.
    Jun 2008
    1104
    Re: Hurco VMX30 bad HDD
    It depends what CPU you have. If you have a Peak715, you can use standard disks but if you have a Peak777, you’ll need standard disks but will need to replace two files after the software is loaded. It sounds like you’ve lost your config files. Do you have a backup on floppy?
    Sep 2009
    8
    I have Peak 777 mainboard, and no backup floppy.
    Jun 2008
    1104
    Have you overwritten your hard drive with the info from another machine?
    Sep 2009
    8
    Yes overwritten. The original disk total deffect. (I haven't floppy disks the machine, only options disk (DXF, pocket, helical))
    Jun 2008
    1104
    Unless you made a copy of the PEAK715.SYS file, you’ve lost those options.
    Jun 2008
    1104
    Where did you buy the machine from? UK? Germany?
    Sep 2009
    8
    I buy Hungary. Do I have a chance to get this file?
    Jun 2008
    1104
    There are only two ways to get them back.
    Reload the option disks using the Hurco software to put them back to unused condition or contact Hurco and send the PEAK715.SYS file to have the options added to it and then re-load it.
    You’ll still be missing the leadscrew compensation file and the toolchanger height figure. There should be a paper copy of the leadscrew file in the electrical cabinet so you can enter all the data manually.
  1. Replies: 3
    Last Post: 04-26-2022, 03:06 PM
  2. Hurco BMC30 system/HDD problems
    By PPG78 in forum HURCO
    Last Post: 06-25-2021, 09:33 AM
  3. Postprocesor for HURCO VMX30
    By Nenad123 in forum HURCO
    Last Post: 08-06-2018, 09:31 AM
  4. Haas VF-2YT or Hurco VMX30
    By pbarsalou in forum Want To Buy...Need help!
    Last Post: 11-01-2008, 03:11 AM
  5. Hurco VMX30 Help
    By forrey45 in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2006, 12:25 AM
