586,111 active members*
3,724 visitors online*
IndustryArena Forum > CAM Software > Alphacam > 4/5 Axis Fanuc Post processor
Results 1 to 3 of 3
    Oct 2018
    3
    Hi there,
    I am loooking for a 4/5 axis post processor for Alphacam for the following machine
    GOODWAY GS-200 CNC lathe
    Any help would be appreciated
    Dec 2005
    68
    Re: 4/5 Axis Fanuc Post processor
    Did you ever found a post processor , there is not much information about Alphacam post processors and commands to change the garbage the send you with the program , what they send you are samples not a real working post
    i try a fadal with 4 axis (A axis) and is not working funny part i have the maintenance program and they told me that they are not giving support on any sample post (they provide) or modified , so i am screw and i will need to buy post from them to get support and never answer my question about machining a solid with 4 axis , that part is not related with the post . i will have to think if wort it to pay maintenance at all , since i have the program i report a lot of issues and bugs , hey never fix any
    ej if you want to make a groove on a specified angle with an angled tool you can't to the contrary Mastercam does it or take in consideration uncut material (lathe module) , also machining tool menu if it is not on wizard mode groove menu change the wide of cut to 0 when you change to the next tab and freezes the program
    Apr 2010
    89
    Attached is a Fanuc 20IT XZCY Axis Lathe Post with Sub Spindle.
    Carefully read the notes at the beginning of the Post.
    Hope this works for you, let me know if any changes needed.
    Regards.
    Attached Files Attached Files
  1. Replies: 0
    Last Post: 03-31-2020, 02:59 PM
  2. Post processor mill turn fanuc oi-tf with c axis
    By bogdy_fb in forum Post Processor Files
    Last Post: 10-05-2019, 05:59 PM
  3. help post processor 5 axis of fanuc 18i
    By hmtam1311 in forum PTC Pro/Manufacture
    Last Post: 12-11-2017, 02:01 AM
  4. Replies: 0
    Last Post: 11-16-2017, 10:00 AM
  5. Replies: 0
    Last Post: 04-04-2015, 08:54 AM
