586,103 active members*
3,828 visitors online*
    Sep 2007
    5
    harmonic drive helps
    Hi!
    i was given a project to model a harmonic drive system driven by dc servo but nw i dunno where im suppose to begin... i had did my homework by studying the working principle, availability of diff types...but its very difficult to get knw the whole things just by reading...my problem is i need to buy all my stuffs frm oversea which means i must knw correctly wat i want to buy b4 placing orders...
    i dunno how actualy we attach the servo to HD...and can any servo be attached to any harmonic gear?
    any suggestion for which gear i should buy?(my project is not for any application, just do research for general purpose drive)
    im not asking any1 to do my project for me, its just that i hope that sm1 can provide me guidance.
    Regards,
    Confusion
    May 2003
    792
    Aug 2006
    102
    Smile
    walter, did you ever build the housing you mentioned in thethread you linked too? thanks greg
    May 2003
    792
    No. I found the entire assembly on ebay and that part went into the dustbin.
  1. Home Made 4th Axis with Harmonic Drive Unit!
    By widgitmaster in forum Benchtop Machines
    Last Post: 08-27-2017, 03:16 AM
  2. harmonic drive, max RPM stepper or servo
    By Art Ransom in forum Mechanical Calculations/Engineering Design
    Last Post: 12-12-2006, 05:26 AM
  3. Harmonic Drive
    By juzwuz in forum Mechanical Calculations/Engineering Design
    Last Post: 12-03-2005, 08:28 AM
  4. Harmonic drive - keeping position?
    By medved in forum Mechanical Calculations/Engineering Design
    Last Post: 12-01-2005, 01:49 AM
  5. Mill Expert Helps Build the Ford GT
    By OneCNC in forum OneCNC
    Last Post: 11-07-2003, 02:17 AM
