586,047 active members*
3,772 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Nakamura-Tome TMC-35 Start up error codes, operator message
Results 1 to 8 of 8
    How do i solve this error codes?
    Im a beginner with fanuc and cnc machines.
    Re: Nakamura-Tome TMC-35 Start up error codes, operator message
    Startup sequence
    Aug 2019
    145
    Those error codes are displayed through the ladder (PMC) and caused by inputs (X address'). Given there are several and they don't seem to tie directly to one another based on the text, I would suspect either a loose common wire/connector, tripped breaker, or fuse.
    The electrical schematics will definitely aid with this one.
    Hello, there was one tripped fuse for the control panel, so now all the light on the control panel are working and near all the error codes are gone.
    But I also get one new error code.
    All the batteries was bad so I changed these, but I forget to do it with the machine powered on so now I have to return the axis to zero/home position.
    What do I do now?
    I tried to move the axis but when I press the floor pedal and on the jog buttons nothing happens.
    Aug 2019
    145
    1st thing to be done is clear the emergency stop state (EMG). That should clear the reset state and allow you to continue. Depending on the fuse that blew and the cause worst case is some inputs or outputs got damaged. Lets hope for the best.
    Quote Originally Posted by oetkbyentc View Post
    How do I clear the EMG? I saw In a fanuc tutorial video RESET+CANCLE(CAN) I tried it but it didn't work.
    Aug 2019
    145
    If releasing the Emergency stop button does not do it directly there may be another button (master start, machine on etc) to push. If not there is an electrical / logic issue preventing the control from coming out of e-stop.
    If that is the case you will need to reference the schematics to check the e-stop string.
  1. nakamura tome 15 310,320,316,326 error codes fanuc ot
    By evro81 in forum Turning Machines
    Last Post: 10-28-2019, 03:06 AM
  2. Nakamura-Tome TMC-15
    By vance1911 in forum DNC Problems and Solutions
    Last Post: 08-18-2017, 09:25 AM
  3. NakaMura Tome TMC-30
    By Faraco in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2011, 03:05 PM
  4. Nakamura Tome TMC 12
    By zavateandu in forum Fanuc
    Last Post: 05-10-2011, 06:51 AM
  5. Nakamura TMC 4 TOME
    By mjblum in forum Uncategorised MetalWorking Machines
    Last Post: 11-05-2008, 05:36 PM
