586,033 active members*
3,518 visitors online*
    Apr 2009
    21
    machine handling
    I may have just purchased an old yonchin cnc mill. My company says I can,t use their forklift to load it on a trailer tho. Also I have no way to unload it or move it when I get it home. It weighs about 2500lbs or less. Any suggestions on how other people have done this and gotten it in there garage?
    Apr 2018
    133
    Re: machine handling
    One possibility is to call a local flatbed tow operator and see what options they can offer you.
    Dec 2013
    5717
    Renting a forklift might be a good option. If it really only weighs 2500 lbs. then good pallet jack could be used to move it around, also available for rent. At 2500 lbs, I would want a minimum of a 5000 lb forklift. Using a drop deck trailer is my prefered method for hauling. My local rental shop has a 10,000 lb drop deck trailer for about $55/day. You'll need ratchet pullers, straps, chains & binders for moving and securing the load. Above all, get some help, and think through what you are going to do before you do it.
    Hiring a machinery mover might be a very good option if you don't have experience moving machines.
    You could build a frame and put it on wheels. Here is a picture of one machine in my shop that is on wheels. I didn't do this, and it doesn't look very substantial, but it seems to work fine. About a 5000 lb machine.
    These are about 5 inch castors and the angle iron is 3/8 thick, just bolted to the cast iron base. We just rolled it out of the trailer, while controlling it with ratchet pullers.
    Jim Dawson
    Sandy, Oregon, USA
  1. Material Handling
    By herrmc in forum Waterjet General Topics
    Last Post: 08-08-2016, 05:27 PM
  2. handling Sinumerik 3M
    By suchender in forum SIEMENS -> GENERAL
    Last Post: 08-21-2011, 10:23 AM
  3. Acid Handling
    By yoopertool in forum Mass finishing equipment/media/strategies
    Last Post: 04-01-2010, 05:26 PM
  4. Material handling robots?
    By REVCAM_Bob in forum Community Club House
    Last Post: 10-13-2009, 10:10 PM
