586,032 active members*
2,909 visitors online*
    May 2022
    4
    test the spindle from China
    I received the spindle, ordered it in China. It was suspiciously cheap.. I checked the beating on the cone - 2-3 thousandths, then put the mandrel under the tool - the beating of 4-6 thousandths. It seems normal. Then I plugged it in, it rotates gently and without vibrations. How else do I test the spindle?
    Attached Thumbnails Attached Thumbnails IMG_20220503_133503.jpg   IMG_20220503_143939.jpg
    Quote Originally Posted by RudolfNL View Post
    I think next testing should be just running it. Most Chinese spindles (from reputable sources anyway) are actually quite good, so just go ahead and use it.
    Apr 2004
    5737
    Re: test the spindle from China
    You might check to see if it's internally grounded. For some reason, a lot of these spindles aren't, which makes them a shock hazard as well as potential emitters of radio frequency interference.
    Andrew Werby
    Website
    May 2022
    4
    oh... thanks, I'll check it!
    May 2022
    4
    By the way, I also heard that spindles from China are good. It's just my bad luck (
  1. spindle stop / mount test indicator
    By averageJoe576 in forum Taig Mills / Lathes
    Last Post: 05-22-2018, 03:12 AM
  2. Milltronics VM-17 vfd spindle enable, spindle test.
    By plane captain in forum Milltronics
    Last Post: 02-10-2016, 04:36 PM
  3. Spindle Test Porter Cable Vs. Bosch
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 05-08-2008, 11:59 PM
  4. First test of Series I Boss 6 mill? Spindle inop...
    By Mr. Technical in forum Bridgeport / Hardinge Mills
    Last Post: 07-13-2007, 05:12 AM
  5. spindle test
    By 69owb in forum CamSoft Products
    Last Post: 06-10-2007, 03:19 PM
