586,832 active members*
3,187 visitors online*
Thread: vero visi
Results 1 to 6 of 6
    Jul 2006
    51
    vero visi
    any mold designers outhere using vero visi to design...any good?
    Nov 2004
    139
    Visi
    Hi Spider,
    Im also a Visi user, I started using this software not long ago and I found that this cad/cam software has potential. From what I know, some of my friends are using this software to import 3d files such .stl, Iges, etc.....then convert to nc code then import to Roland machine to engrave and of corse you need a post processor
    (.cfg extensions) for Roland machines.
    happytriger2000
    Mar 2006
    61
    Ive had a demo version of this product. it is very capable also it has the machining from machining strategeist incororated. which is my favorite package which i have as a stand alone product. visi itself i am not fond of for only one reason that is there is no history of how a 3D model was built which is sometimes an advantage when customers change their mind about a design and you can go back and alter a particular part of the geometry.
    Mar 2008
    14
    It is easy to use as a 3D modeller for simple one-off parts but because it doesn't have a parametric database (i.e. a history of how the model was constructed), you are better off using Solid Edge or SolidWorks to do the part design work.
    But as a CAD/CAM package it is extremely capable. Also, the VISI-MOULD add-on is great for splitting parts into core and cavity, generating the split line and constructing the mould tool around it all.
    There is also a VISI-FLOW add-on available for doing Moldflow work and a 5-AXIS CAM add-on.
    Jun 2008
    I have been Using Visi for years and find it very powerful...it of coarse is not a parametric modeler however this has its advantages as you aren't dedicated to following rules of constraints.
    Jan 2015
    Re: vero visi
    I study Vero Visi. I think that Solid is better then Vero Visi. Video tutorials where you can download?
  1. Vero visi postprocessor
    By tar_gh in forum Postprocessor for CAM
    Last Post: 11-08-2022, 03:00 PM
  2. Vero Visi
    By ion the gr in forum Visual Mill
    Last Post: 01-08-2015, 08:40 PM
  3. Someone uses VISI Machining 5 Axis - vero soft
    By AlphaSpan in forum Uncategorised CAM Discussion
    Last Post: 07-09-2014, 07:59 AM
  4. Vero Visi Fanuc α-0i post processor
    By G9611 in forum Post Processor Files
    Last Post: 04-18-2014, 03:47 PM
  5. VISI vero forum?
    By CRS1 in forum Uncategorised CAM Discussion
    Last Post: 12-08-2013, 10:45 AM
