586,102 active members*
2,485 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > How do i get my autocad file onto mastercam?
    Aug 2003
    well bassically ya I'm quite new to all of this, usually i am able to figure it out myself when i come into problems, but im stuck on this one.
    Im trying to get a file from autocad, to open in mastercam so i can create toolpaths and an .nc file
    What i want to be able to do is take a .jpg file and engrave it onto a piece of wood. I have used corel draw to get the .jpg file to convert to an autocad file, but now im stuck in trying to get it onto mastercam
    I thought that all i had to do was make the cad file a .dxf, then open mastercam>file>converters>then open a dxf file and it would bring it onto the mastercam screen. and well im doing htat, but then the mastercam screen stays black. all i am trying to change is a simple 2d box that i created, soo im wondering if that is the problem.
    Im quite stuck here, any help would be greatly appriciated
    thanks
    Ed
    Thanks!
    Ed
    Apr 2003
    3578
    Ed what version of MC are you using?
    this tells me what to tell you waht you can do and not due.
    thanks
    Cadcam
    Feb 2011
    I am having the same problem, using CS5 Illustrator to convert a jpeg to dxf for use in Mastercam X4, and it shows up blank in Mastercam
    what is the software conversion syntax?
    May 2006
    803
    Mastercam art will use a raster file and convert to vector geometry, with some trials,testing with the settings, it's too easy.
    Been doing this too long
  1. Emco Compact 5 PC...have ????
    By Double G in forum Mini Lathe
    Last Post: 08-23-2010, 12:26 AM
  2. need Autocad .dwg file converted
    By RcCNC in forum Mastercam
    Last Post: 04-29-2005, 10:10 PM
  3. Link a Mastercam File to Excel
    By stampman in forum Mastercam
    Last Post: 03-07-2005, 11:16 PM
  4. Autocad to Mastercam trouble
    By Vapour in forum Uncategorised CAM Discussion
    Last Post: 10-12-2004, 07:45 PM
  5. AutoCad 2000 Missing .dll file
    By E-Stop in forum Autodesk
    Last Post: 05-30-2003, 05:43 PM
