586,111 active members*
3,543 visitors online*
Results 1 to 7 of 7
    Jun 2022
    Lasers.................I have NO IDEA - HELP!!
    So I have stumbled onto a "niche" business opportunity that involves cutting "fit check" templates out of thin acrylic and posterboard-type stiff paper (1/16" thick). I believe a laser would be the most accurate and effective but I know absolutely zero, zilch, nada, about lasers. I'd need something that could cut about 18" x 30" templates, 1/16" thick acrylic and posterboard-type thick paper. This would be repetitive cutting on a fairly large scale (20-40 cuts a day). Any help would surely be appreciated.
    Mar 2011
    19
    Re: Lasers.................I have NO IDEA - HELP!!
    1/16" acrylic and posterboard? Even the cheap K40 will do that.
    Jun 2022
    Again...................I know absolutely nothing at all about lasers. "K40" means the same to me as "ABC123".
    Jun 2022
    The "K40" i see on Amazon is only for 8x12 pieces. Again, this is for a minimum of 18" x 30" and for high volume.
    Apr 2005
    304
    Look for 6090 lasers 60x90 cm -> 23x35 inches
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Sep 2005
    1195
    check atomstack x20 pro 130w laser ...
    Apr 2005
    304
    atomstack x20 ic about 20W emited laser power, 130W electrical input.
    CO2 laserr tubes are declared on true laser power OUTPUT.
  1. Looks like the Camera idea on lasers is changing the laser world like Glowforge, Muse
    By videorov in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-13-2021, 07:48 AM
  2. Retro-Fit... Good idea or bad idea?
    By sen2two in forum Milltronics
    Last Post: 01-11-2019, 03:01 PM
  3. New to lasers
    By Devastator in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-03-2015, 07:34 PM
  4. New to Lasers
    By JUNKYCOSMO in forum LaserCut
    Last Post: 03-24-2015, 08:07 PM
  5. Lasers
    By goldwing199 in forum MetalWork Discussion
    Last Post: 05-12-2011, 03:03 AM
