586,103 active members*
3,404 visitors online*
    Tool Travel Height
    I was trying to figure out how to change the tool travel height when its going over the top of the material. When cutting the tool is traveling to close to the material and hitting it at times. For instance. I am running a piece of corrugated. Warped pieces at times let go off the vacuum once its cut.
    I have been search the forum I cant seem to find if someone has already answered this. I'm pretty new to this machine. I would appreciate any help. I have looked in the tool manager and the tools in Aspire. I cant seem to locate something to adjust it. I would rather the tool come up a inch above the material. Right now its at about an 1/8th. Thanks in advance
    Re: Tool Travel Height
    The machine is a Trident 4010. Forgot to add that in.
  1. Fadal 6535 Z travel height
    By EliteCustoms in forum Fadal
    Last Post: 07-21-2021, 12:25 PM
  2. Help wiring Tool Height/ Z axis height base into C10 BOB
    By SpecialEd in forum Tormach Personal CNC Mill
    Last Post: 11-21-2016, 02:13 AM
  3. Relative safe travel height and potentially other suggestions
    By jm82792 in forum Uncategorised CAM Discussion
    Last Post: 02-11-2012, 08:54 PM
  4. Changing rapid travel height at the machine
    By Bigrhamr in forum DynaTorch
    Last Post: 08-06-2010, 06:59 AM
  5. OPTIMUM BF20L mill, z-travel exactly from table height ?
    By vroemm in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2009, 10:01 PM
