586,076 active members*
3,873 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Tool Changer making honking noise at end of tool change
    May 2013
    167
    I have been having an issue on my umbrella style tool changer on my Super Mini Mill where there is a slight delay at the end of the tool change. I just changed my air solenoid valve ( labeled "A" on my photo )
    That seems to help, but on about every 5th took change there is still a delay.
    I took the cover off the part labled "C" and sprayed some mass air sensor cleaner inside that, and now I'm getting a honking noise at the end of the tool change. ( The best way I could describing his like a goose call )
    I'm running an air dryer on my air lines.
    Any suggestions ?
    One other question.... The Part labeled "B" appears to be an adjustable regulator, I haven't touched that yet, but just wondering if thats something I should look at adjusting?
    I have posted a video on Youtube showing the slight delay, and the honking noise.
    https://youtube.com/shorts/OwzfPm1rCvA
    Kent
Name:	Tool Changer.jpg
    Jan 2008
    19
    Re: Haas Tool Changer making honking noise at end of tool change
    could be the Humphrey valve screwed into the right side of the solenoid valve you have labeled C. the diaphragm inside is mostly likely junk. might check it out.
    landy
    May 2013
    167
    Thanks Landy,
    I swapped out the Humphrey Valve and that did the trick..... Back up and running at full capacity!
    Thanks again...
    Kent
    15362
    Quote Originally Posted by kentdesautel13 View Post
    Any suggestions ?
    Kent
    You should never use that type of cleaner on pneumatics, apart from the valves you replaced you may be near the time to do the main air cylinder and the Draw Bar as these need cleaning and new lube usually around the time the valves need replacing, a new Oring for the main Cylinder Piston is needed when you do this. you don't have to buy Haas parts for any of this repair
    Mactec54
  1. Replies: 7
    Last Post: 08-14-2020, 02:13 PM
  2. Replies: 3
    Last Post: 05-24-2019, 07:43 PM
  3. Abort during tool change - tool changer stuck
    By yugami in forum Milltronics
    Last Post: 07-24-2018, 10:37 PM
  4. Bridgeport interact 412 tool changer does not slow b4 tool change
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2013, 10:50 PM
  5. Tool Changer Noise !!
    By chipsahoy in forum Fadal
    Last Post: 10-09-2010, 06:36 PM
