586,609 active members*
3,456 visitors online*
Results 1 to 7 of 7
    Jan 2022
    107
    Question M49 freezes current version of TNG
    I have some programms, where I use M49 to disable spindle and feed override.
    That was working in the previous version of tng, but with the current version, the entire application freezes and could only be closed with taskmanager.
    If you cant reproduce this, I may send you gcode with the issue.
    Mar 2017
    1317
    Re: M49 freezes current version of TNG
    I can not reproduce this.
    Jan 2022
    107
    I have attached the sample gcode which also freezes TNG in Simulation.
    I just added G9 directly before M49 which solves the problem. But that wasn't an issue before.
    Attached Files Attached Files
    Mar 2017
    1317
    This g-code ran fine on my machine. Export and send me your profile .zip file.
    Jan 2022
    107
    Profile attached.
    You may need to do "homing" even in simulation to be able to start the gcode.
    Mar 2017
    1317
    Please try latest version.
    Jan 2022
    107
    I can confirm that the issue is solved.
    Thank you.
  1. TNG Latest version
    By Eatonbrayer in forum PlanetCNC
    Last Post: 02-16-2019, 01:05 PM
  2. Sprutcam 8, what is the current version
    By scottsss in forum SprutCAM
    Last Post: 06-07-2013, 04:57 AM
  3. last current deskcnc version
    By ljd10 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-13-2012, 04:45 AM
  4. Looking to purchase a current version of Mach 3
    By rkelemenHHR in forum Machines running Mach Software
    Last Post: 04-08-2011, 12:23 AM
  5. Current ISOGRAPH version
    By prinzvalium in forum Fidia
    Last Post: 01-16-2011, 06:43 PM
