586,042 active members*
3,802 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Machining Centres > Positive Pallet Identification
    Jun 2022
    5
    Hello all,
    I have a 2016 Matsuura H+400 with a G-Tech 31-i control. It has a 6 pallet pool with Matrix. I am trying to use the weekly timer function to run a program that warms up the spindle + XY axis, and does a calibration check for the probe(s). I have to run this program on a specific pallet and face. I am having some difficulty gathering the information required to achieve this.
    I am looking for any information regarding the following:
    1. has anyone done this before? if so, how?? if not, see #2.
    2. how does the machine know which pallet is in the machine, and is that information an accessible variable?
    3. are there accessible variables that control the red star and readying of pallet face?
    -Brad
    Apr 2012
    85
    Re: Positive Pallet Identification
    Brad,
    The control will send the machine pallet number to a macro variable.
    You have to set the variable number in DATA TABLE D12420. (System, >, PMC MAINT, DATA, OPRT, ZOOM)
    You have to make certain the variable number is not being used by another program/function as it will override each other.
  1. Mazak H-400N - Pallet change doesn't clamp pallet issue
    By moneynet in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-15-2020, 01:59 AM
  2. MV-40 with Pallet chnager Pallet stuck
    By IAG1 in forum Questions or Problems
    Last Post: 08-14-2018, 05:43 PM
  3. Positive angles
    By GBRAVO in forum Visual Mill
    Last Post: 06-23-2009, 04:33 AM
  4. Pallet Identification on Daewoo w/Mits control
    By davey242 in forum Daewoo/Doosan
    Last Post: 08-28-2007, 04:29 PM
