im interested in which type of laser i could use to cut balsa wood say up to 3/8" ingh and maybe ply, then where do i go to buy one. any suggestions please.
you can also check out
www.alspi.com
we have been building custom lasers for many years. From yag etchers to 6k CO2 systems for real cutting. (ha ha real cutting)
Hi Experter,
If I want to cut the wood thickness about 1 inchs, How many watts for laser power properly?
Cheers,
Mongkol
I personaly would hit it with about 500 watts. if you hit it with more than is needed. What you wind up doing is vaporizing the material, not flaming thruogh it. I have not been using one of these table top little models. I work at ALSPI who can be found at www.alspi.com. so I also hit it with a shield gas of nitrogen about 12-18 bars of gas. that works better for me when cutting wood. if I am cutting .5 thick metal I use conditions for that as well but use Oxygen not to shield but as an assist gas. these little things that have less than 1000 watts well that is a hobby toy to me. sorry no offend ment.
I think you can cut 1" with a 100 watts lCO2 aser, at low speed.
