586,058 active members*
3,768 visitors online*
    Pulse and Direction Signals Not Working
    I'm having trouble getting the pulse and direction signals working on my machine. I have a CNC gantry router with clearpath motors. I am using CNC4PC C68 connector board on my Kflop to connect to the UCBB break out board which is also from CNC4PC. I can get the machine on, initialize and home it, but the enable won't turn on. Once the machine is done homing, it essentially does nothing. If I don't setup the motors in the c program, then I can use the kmotion software to toggle the enable. But when the c program includes the motor setup you can't use the software to force the enable on.
    I attached my C program for Initializing. What am I doing wrong?
    Derwin
    Attached Files Attached Files
    May 2006
    4045
    Re: Pulse and Direction Signals Not Working
    This was a double posting and answered here.
    TK
    http://dynomotion.com
  1. NVEM ethernet step and direction signals
    By dmauch in forum Controller Cards
    Last Post: 01-10-2019, 06:42 PM
  2. Identifying a860-0360-t101 pulse coder signals
    By andrewboerder in forum Fanuc
    Last Post: 07-01-2018, 02:51 PM
  3. step pulse and pulse direction
    By peregrinus in forum Mach Software (ArtSoft software)
    Last Post: 03-21-2011, 02:04 PM
  4. Step and direction signals
    By harshasunder in forum LinuxCNC (formerly EMC2)
    Last Post: 12-04-2009, 06:08 AM
  5. How to generate fast step/direction signals
    By amitgoradia in forum Open Source Controller Boards
    Last Post: 10-17-2008, 08:58 AM
