586,096 active members*
3,112 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > It’s been a while still initializing found this though
    Nov 2012
    145
    The Avenger 250T sill isn’t fixed but I found this in the manual (last page)
    Does anyone know about this?
    Attached Thumbnails Attached Thumbnails AD8B679F-867D-4FC2-A2F7-D5DC983A5C21.jpg
    Dec 2006
    584
    Re: It’s been a while still initializing found this though
    Nov 2012
    145
    Strange it’s only a picture of the page
    Mar 2008
    285
    The page you show is the Initialization of the Spindle Drive Parameters; prior to entering them from a Factory Set-up Sheet. Contact Fives-MSI 1-859-534-4750 if you need more.
    If the control screen shows "Initialization Required" that is due to a power failure, or reloading of software and totally different.
  1. Mazatrol T32 initializing
    By terra103 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-13-2023, 06:33 PM
  2. HELP! PlasmaCAM Doesn't Finish Initializing
    By humbyrds777 in forum PlasmaCam
    Last Post: 06-13-2018, 02:32 AM
  3. Z axis trouble while initializing?
    By Bradsky in forum PlasmaCam
    Last Post: 12-20-2011, 07:01 PM
  4. Battery change and initializing position _ NL series
    By aidenkim in forum Mori Seiki lathes
    Last Post: 08-26-2011, 02:28 PM
  5. Re-initializing Controller Software
    By Geof in forum Haas Mills
    Last Post: 03-18-2007, 06:54 PM
