586,065 active members*
4,721 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Looking to order first ever CNC machine have a question about a Dual Z axis
Results 1 to 6 of 6
    Hello,
    I am looking to order my first ever CNC machine, and I am considering an Avid. I would require a dual Z axis, with a spindle and a EOT-3 Oscillating Cutting Module. I was wondering if anyone has this setup or something similar and if it was successful. Any insights would be appreciated.
    Thank You!
    Nov 2013
    4373
    Re: Looking to order first ever CNC machine have a question about a Dual Z axis
    what material are you cutting? The material determines the rigidity required of the machine.
    A mill that can cut steel is often many thousands of pounds of cast iron, whereas a 4' x 8' router for wood may weigh less than a thousand pounds.
    Craig
    Dec 2021
    31
    We produce DRO and grating ruler, maybe it will help you, you can go to https://www.amazon.com/stores/HHXXOV...2?ref_=ast_bln
    view on
    Jan 2012
    222
    Quote Originally Posted by Dmartens86 View Post
    Hello,
    Thank You!
    I have a PRO60120 with dual heads and extended gantry. My first recommendation is to make sure you buy both axis the same size. That is very important because Mach4 and the way AvidCNC has set it up.
    Personally, I love having the spindle and plasma in one machine. Sure it was a pian to move the water table until I purchased a 2 ton engine crane and now its about an hour to convert. If I had to remove the spindle to do that it would take about 12 hours and a bunch of test cuts each time to realign things.
    Do NOT get the dual heads without the extended gantry. You will hate yourself. I don't think they even offer that option anymore, which is good.
    Personally, I love my dual process machine!
    By all means, if you got the money, do it....
    BUT!!
    I have no idea about that tool you are planning on using.
    All AvidCNC machines over the 4x4 ring like a bell. They make great woodies but it will leave that ringing effect on the surface of your metal unless you slow waaaaaay down. Just google "3d printer ringing" and you can see an example of what I am talking about. These aluminum extrusion machines are springy and light. Very flexible and it shows at high speeds. You can actually see it in wood too if you know what you are looking for. But with wood its easily removed with a light sanding. Metal? Aluminum? Even a long time in a tumbler with an aggressive medium and you can still see it.
    --jb
    Eva Foam, so the rigidity of the Avid will work
    Jan 2012
    222
    Yep! You are not going to have difficulty with that. Probably the only thing easier to cut than HDPE.
    I enjoy my dual process machine. I am about to put a 20 watt LED laser head on the same axis as the plasma torch. When the fiber lasers come down in price a bit then I will step up to that.
  1. Specifications for new CNC Machine Order
    By Kevaleru in forum Chinese Machines
    Last Post: 11-02-2023, 04:50 AM
  2. 6 axis (3+2 with dual spindle) Mach3 question
    By GarageFiddler in forum Mach Software (ArtSoft software)
    Last Post: 09-04-2014, 01:51 AM
  3. dual x axis stepper question
    By tkms002 in forum DIY CNC Router Table Machines
    Last Post: 03-23-2011, 09:37 PM
  4. Dual Z-axis Machine Examples??
    By Zuni in forum DIY CNC Router Table Machines
    Last Post: 03-13-2011, 08:14 PM
  5. Dual Steppers or Timing Belt for Dual X-axis?
    By GEBrown in forum Linear and Rotary Motion
    Last Post: 05-27-2010, 05:45 PM
