586,094 active members*
4,000 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > ethernet NVEM v2 Novusun mach3 board "device not ready" ?
    Jan 2022
    11
    Hello.
    I have purchased a Ethernet NVEM v2 Card, pasted the plugin and xml file in the right folders but when i try to move an axis, mach3 just displays "device not ready" in the message box.
    Any ideas on what i can do? I have also found a "bin file" online, but i don't know what to do with it.
    It's a shame because a 100€ card can't be easily connected to the PC, Novusun doesn't reply neither does the seller.. and i can't return it anymore.
    Thank you for your help.
    Attached Thumbnails Attached Thumbnails WhatsApp Image 2022-06-24 at 2.12.03 PM.jpeg   WhatsApp Image 2022-06-24 at 2.12.02 PM (1).jpeg   WhatsApp Image 2022-06-24 at 2.12.02 PM.jpeg
    Nov 2013
    4375
    Re: ethernet NVEM v2 Novusun mach3 board "device not ready" ?
    because Novosun has been caught repeatedly peddling pirate copies of Mach3 you will get zero support from the Mach Forum.
    To be honest you may think the controller is cheap, but if you cant get it to work and you cant get help from either the manufacturer or the seller then
    its not cheap at all, but a waste of money.
    The .dll file must be installed in the Mach3 Plugins folder. Good luck
    Craig
    Jan 2018
    1516
    Should've read up on nvum/nvem controllers before hand.
    You would've been put off.
    They're copied left right and center, have zero support, bundled with pirate mach3 software and.. The dll plugins have not been updated for a very long time (pre win10). Getting them to work on the pc is 50//50 or less.
    I'll admit I started with a pirate mach3 and parallel bob (that worked) to see if I liked messing with cnc equipment. I've now bought into UCCNC and a UC300eth and don't regret it.
  1. NVUM v2 version CNC Controller 3-Axis "device is not ready"
    By adamfromUK in forum Controller Cards
    Last Post: 12-16-2019, 07:23 PM
  2. NVEM 200KHz Ethernet Mach3 Card
    By Abdulwhab in forum Controller Cards
    Last Post: 09-07-2018, 02:08 AM
  3. "Breakout board & motor controllers" v "Stepper motor driver controller board"
    By atkinsonp in forum CNC Machine Related Electronics
    Last Post: 10-21-2013, 09:41 PM
  4. "BRAKE BOARD" NEW Design for MACH3
    By Chivo in forum CNC Machine Related Electronics
    Last Post: 04-08-2007, 06:01 PM
