I'm new here and plan on thermoforming Jeep Cherokee Fender Flares. The Jeep gets used offroad so the Fender Flares take serious abuse. Jeep Pict in action
I've not built a former yet but am gathering components & information. The former will need to be around 24x48 to accomodate the flare dimensions.
Forming Material: LDPE, HDPE, other options? Ideally, the fender flares would need a considerable amount of flex for random encounters with trail obstacles. I am not well versed in different plastics. I think ldpe is very flexible and might work but it would need to be in black and that I've not found so far. Also, Seaboard® HDPE from Professional Plasitcs might work but it is an extrusion and it doesn't say if it's formable. It would be much more rigid, which is not as good, but is available in colors.
Material Thickness: The product also needs to be thick. I'm thinking at least .25" if not .375". Obviously this will also affect the design needs of the former.
Material Color: White or clear is obviously not an option unless easily paintable. Black is fine. Other colors would be useful in the future.
Vacuum: Any suggestions on the amount of recommended vacuum would be great. Everything I've read so far seems to be for .25" or thinner plastics. There would not be a huge amount of detail needed and the mold would be around 6" high. Based on the material thickness I'm assuming a two stage system?
Vacuum Pump: Has anyone had experience converting an old York style car A/C pump (such as the ER210) into a vacuum pump? The York is an oiled pump with a push/pull design and puts out at least 4.5 cfm on the compressor side.
Molds: Obviously, the flare needs to meet the Jeep sheetmetal properly but I'm not sure of the best way to create the form. MDF would require a lot of scribing and fitting.
Well, this is already long. I'm looking forward to hearing your advice!
Doug
