i need help guys.
baude rate set at2400.
made up 232 cable
wont transfer program
[extin/output not ready]
had machine in edit . is there something i,m missing? what do you think Gus? help please
Dar
i need help guys.
made up 232 cable
Dar
Be quite helpful to know what contoller you are trying to either load or dump from, and what software you are using at the other end of the link. Dependant on controller it may also depend on which machine it's fitted to and thus how it is configured.
Vague questions will result in vague answers whereas specific questions may get you useful answers
Andrew Mawson
East Sussex, UK
maybe this will help?
bp series 2 r2c3
heidenhain tnc145
ez cam
9 pin connector on pc
cable made using manual discription
does this help?
Dar
Sorry, no experience with either TNC145 or ez cam. With my TNC151b I initially had loads of problems as I failed to understand that it could exist in several 'modes' when intending to do a transfer. I found that using TNCremo from Heidenhain (free download) and the cable in their manual (also free download) eventually got me going. TNCRemo has a mode compatible with TNC145 so it may be worth your while trying it.
Andrew Mawson
East Sussex, UK
i went to heidenhain site but wasn,t able to find it. i was hopping we were just pushing the wrong buttons to make it transfer.
Dar,you can download the software here.
http://filebase.heidenhain.de/public/?open[]=64&open[]=55#GROUP55
and here
http://www.heidenhain.com/?/ca2243_1...ware-3083.html
Mark.
thank guys i,ll give that a try
does anyone have the correct wiring for the rs232 cable when going from a25 pin machine to a 9 pin pc. heidenhain tnc145 on series 2 r2c3. i can,t even read those little numbers without a magnifier.
thanks Dar
As per the response to your other thread on RS232 cables, this is the cable I use from my TNC151b to the 9 way on my PC:
(25way TNC) <9 way PC>
(2) - <2>
(3) - <3>
(4) - <8>
(5) - <7>
(6) - <4>
(7) - <5>
(20) - <6>
Andrew Mawson
East Sussex, UK
Hth
thanks to everyone especially bborg the no handshake one worked. sure is hard to solder wires into those little bitty pins
Dar
