586,388 active members*
3,364 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Cant manually create a new program in FANUC O-M controller
Results 1 to 6 of 6
    Jun 2022
    6
    Hi all,
    I recently got a ANDI Stratos/SUP cnc mill that uses a FANUC O-M contoller. It uses a rs-232 to input programs into the machine, but I have been unable to do so. I tried to create a new program by doing PGRM -> O0001 -> Input but it does nothing, and I think these two problems are related. Does anyone know how to fix this?
    Re: Cant manually create a new program in FANUC O-M controller
    Usually it's a EDIT protect Key switch. May be under the software operator's panel
    Aug 2009
    1573
    ...try Sending a program CNC to PC to test cable wiring, Most common cables are Null Modem type....next check for Format of the program you're try to load. Sometimes a blank Line (aka CR LF) at the beginning of a program is needed.
    Also, make sure the PC is electrically Grounded correctly or things can get fried
    Jun 2022
    6
    On our machine it is a physical key switch and we made sure it is turned off.
    Jun 2022
    6
    - - - Updated - - -
    It appears our machine had the key switch mislabeled, turned it the other way and now we can manually create programs. Cant input programs still but wondering if that has to do with a wrongly wired cable.
    - - - Updated - - -
    Jun 2022
    6
    I discovered that the I/O parameter I was on was wrong, I changed it to 1 so it works with RS 232, and now I am getting a 086 P/S alarm when I try to send a program from CNC to PC or PC to CNC, do you know why that would be?
  1. Replies: 1
    Last Post: 05-16-2014, 02:31 PM
  2. Replies: 3
    Last Post: 03-15-2012, 09:35 PM
  3. Replies: 32
    Last Post: 08-13-2011, 03:30 PM
  4. Send program from PC to Fanuc controller
    By derail in forum Fanuc
    Last Post: 02-26-2007, 10:15 PM
