I may be confused too
I'll try and understand the question you've asked...
Originally Posted by
Cartierusm
says "do this and tune that" "unless you are loosing steps". How do you know if you are loosing steps? Is it a mechanical thing ...
Yes/No/Maybe? Mechanical in How you might see the lost steps.
Without encoders for positive feedback to the control software there is little way for MACH to tell/show you lost steps.
1. Assume the machine is square and not binding, that the motors are working, and all setups are correct.
2. Draw a square - 4 equal length sides in your fav design program.
3. Have a constant cut depth, then
4. convert it to a milling(CAM) program.
5. Run it on your machine. No simulation here - make chips and dust! (Try blue foam to minimize load on your tooling.)
6. Review your Results:
If the square you actually cut -- isn't and the depth changes - you can begin searching each axis for the problem.
Also you might see that the tool doesn't return exactly to the start point (if you told it to go there. Do that after running the cut)!
Hope that helps -
:cheers: Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
