586,070 active members*
3,520 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Mach 3 motion controller card wiring to fuling dzb300 inverter
Results 1 to 2 of 2
    Jan 2020
    Cool Mach 3 motion controller card wiring to fuling dzb300 inverter
    Hey so I have the power wired to the inverter and card but there are 6 multi function connections S1-S6 and I’m wondering what to connect these to on the card, on the card I see where to connect the drivers to the card xyz locations with step and direction +- and then there is a bunch of input and out puts I know several are for limit switches there are 6 total x+- y+- z+- and then there Is also a tool changer with an air relay for opening and closing the chuck so I’m basically looking for how to hook up all the wires on this fulling DZB 300 to a Mach three card with a tool changer and air relays for opening and closing the check on the spindle with a spice rack tool changer that slides from X-to x+ thank you for any help David
    15362
    Re: Mach 3 motion controller card wiring to fuling dzb300 inverter
    Quote Originally Posted by Dreamcnc View Post
    There will only be a connection for the 0n/0ff and the speed control PWM to Analog 0-10v connection
    So S1/DCM=0n/0ff Best to use the Breakout Board Rely for this connection
    VI/ACM=0-10v analog for speed control
    Mactec54
  1. Fuling inverter DZB300 or DZB200
    By bivegele in forum Phase Converters
    Last Post: 10-21-2021, 03:19 PM
  2. Alarm wiring on Rnr motion card (Red)
    By trivalb in forum Leadshine
    Last Post: 05-10-2021, 11:13 AM
  3. Replies: 3
    Last Post: 06-01-2020, 09:40 AM
  4. Fuling DZB300 series VFD and Spindle
    By BJM737 in forum Spindles / VFD
    Last Post: 12-30-2019, 04:28 PM
  5. Replies: 0
    Last Post: 09-17-2013, 05:38 PM
