586,035 active members*
3,814 visitors online*
Results 1 to 5 of 5
    6855
    R90LIM Limit Switch Board
    R90LIM Limit Switch Board -up to 200V/56A
    Suitable for R90H/R990H or 3rd party brush DC motor drives.
    CNC independent - easy installation.
    Connected in series with any brush DC PM servomotor.
    56A continuous current.
    220A pulse current.
    Interface to two low power mechanical or optical switches.
    Employs two isolated high current switches.
    Let www.rutex.com know CNCzone sent you!
    Attached Thumbnails Attached Thumbnails !cid_00d401c437f0$72dbe970$bd00a8c0@dell.jpg
    Feb 2004
    2337
    I still dont quite understand what these do? Can someone please explain in laymans terms? Is it like a solid state relay for turning on and off the power supply to servos? What application would they be needed for?
    Being outside the square !!!
    Jul 2003
    125
    Normally you'd wire up your limit switches and estop to your controller board so that when they are tripped your software will be triggered to cut power to the motors.
    These boards will cut power to the motor when the limits are reached and do not interact with the software. It's just a little safer, perhaps a little easier to implement, and prevents dangerous situations if someone misconfigures the software or such.
    Feb 2004
    2337
    So really it is a solid state contactor?
    Jan 2004
    231
    where would the encoder feedback get sent? to another board?
  1. Solid-State limit switch experiment
    By Swede in forum CNC Machine Related Electronics
    Last Post: 01-08-2010, 08:20 PM
  2. Help with limit switches and Xylotex board
    By dowling177 in forum Xylotex
    Last Post: 11-26-2008, 09:51 PM
  3. idea for limit switch, need opinions
    By replicapro in forum CNC Machine Related Electronics
    Last Post: 06-29-2007, 12:59 PM
  4. mach2 LIMIT SWITCH end of stroke reliese?
    By mike10 in forum Mach Software (ArtSoft software)
    Last Post: 04-25-2005, 04:48 PM
  5. limit switch override
    By swarfmacdaddy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-12-2004, 10:47 AM
