586,111 active members*
3,186 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > ATC. Automatic Tool Changer issue. Leadwell Mill, MCV-OP Fanuc OM controller
Page 1 of 3 123
Results 1 to 20 of 44
    Mar 2011
    230
    Hi guys, I'm starting another thread on the issue of ATC not working.
    A bit of history, the parameters were deleted, i think from the machine being powerless for 3 years??
    Anyhow I have put the parameters back in from an old floppy disk and from my service book.
    The Mill is slowly coming back to life as i can now load programs but cannot change tools even in MDI. The changer basically turns back and forth, it doesn't actuate down and across. (Not an arm type tool changer)
    zavateandu was greatly helping me out a few months ago but i think the issue was because the technician had my service book (4 or 5 months of calling him) which I had to go to and check some parameters and ladders. The ladders is something i have very little clue about other than i think its a series of switches??
    Thanks guys
    Bart
    Aug 2019
    145
    Re: ATC. Automatic Tool Changer issue. Leadwell Mill, MCV-OP Fanuc OM controller
    Are there any PC parameter settings in your manual? On that series they would be Diagnostics in the 300's.
    Looks like a counter or timer is possibly not set. Its also possible that a value in the Diagnostics was set base on the location of the Magazine at that time and is now causing a conflict based on its current location.
    Mar 2011
    230
    thank you.
    ill have to scan some parameters and probably ladders?
    I remember now, its been a few months but i was supposed to share this with zavateandu but i didn't have the manual. I have the manual now so ill scan it.
    Mar 2011
    230
    Parameters
    Mar 2011
    230
    Mar 2011
    230
    Parameters
    Attachment 481820
    Attachment 481822
    Attachment 481824
    Attachment 481826
    Attachment 481828
    Attached Thumbnails Attached Thumbnails IMG_20220705_0020.jpg   IMG_20220705_0023.jpg   IMG_20220705_0023.jpg   IMG_20220705_0022.jpg
    IMG_20220705_0021.jpg   IMG_20220705_0018.jpg   IMG_20220705_0017.jpg   IMG_20220705_0018.jpg
    Mar 2011
    230
    Aug 2009
    1573
    ...just a quick reminder about changing Parameters....you must cycle the Control OFF, then back ON to take affect.
    Mar 2011
    230
    Quote Originally Posted by machinehop5 View Post
    That's a great point. I discovered that with the download issue a few days ago.
    Mar 2011
    230
    2 or 3 of the ladder diagrams show the ATC
    Aug 2009
    1573
    Quote Originally Posted by toranacar View Post
    ...yes, its great you have most if, not all the paperwork with machine. Which makes me wonder what else is on the Floppies you have. Also, does your machine have a Hard Drive? Is there more than one Directory of files...what are the File or Directory names ?
    Mar 2011
    230
    I have more ladder diagrams diagrams. Ill copy more of it.
    Ill have another look at the floppy.
    Jun 2012
    7
    Anyone knows how to disable atc to put my komo machine working tool manually? Which parameter can bypass it and eliminate the alarm of tool changer not ready?
    Mar 2011
    230
    That's a good question, i want to know how to enable it
    Aug 2009
    1573
    ...have you tried Punching the PMC Params from CNC to PC to see if there is anything in there? it might look like random numbers and letters when viewed has a TXT file.
    Attachment 481946
    Mar 2011
    230
    Attachment 481946
    No i haven't. Ill have to try that
    Aug 2009
    1573
    ...8 bit names for files when saving to dos in 1980-90's right?
    Mar 2011
    230
    I have windows XP, i think it has DOS, im pretty sure
    Aug 2009
    1573
    ... more things to find out better late than never and confess ya--- XP time wrap
    130 Keyboard Shortcuts for Windows XP
    Mar 2011
    230
    :lol
Page 1 of 3 123
  1. Tool changer problem Leadwell MCV-760 CR
    By Nilsson.ganda in forum Fanuc
    Last Post: 02-11-2015, 06:11 PM
  2. LeadWell MCV-760 FANUC 0-MF ATC macro
    By cnc35 in forum Fanuc
    Last Post: 08-05-2013, 08:44 PM
  3. CAM: Tool path generation for ATC Automatic Tool Changer
    By S.Seveelavanan in forum Uncategorised CAM Discussion
    Last Post: 08-09-2012, 04:45 PM
  4. ATC automatic tool changer
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 06-29-2010, 08:01 AM
