586,065 active members*
4,301 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Gantry square procedure tutorial with PlanetCNC TNG
    Mar 2017
    1312
    We wrote a short tutorial on Gantry square procedure. We would be grateful for any tips or recommendations to make it more useful or informative.
    https://planet-cnc.com/gantry-square...ith-planetcnc/
    Jun 2021
    105
    Re: Gantry square procedure tutorial with PlanetCNC TNG
    After a quick read, a few things come to mind, both from having done this with my dual Y axis CNC and controller (which uses two sensors and software auto squaring), and from reading your text.
    In no particular order:
    1) I felt it was important to also first have my axes' travel accurate through calibration, before starting to do the squaring
    2) In your text,
    Move V:
    Value of measured misalignment of master axis. This is the distance for which slave motor will retract.
    ... was it to read "Value of misalignment of 'slave' axis." ?
    3) I prefer to use the largest distances to determine if the axes are square, so instead of cutting a small square and using calipers first, I use the 345 triangle method. making small holes/dots in the waste board with a 15 degree V bit, then measuring the hypotenuse with an accurate mm ruler. Then adjust accordingly. The cutting and caliper measure of a square I would do as a final check.
    4) I would add a diagram that illustrates what the user finds with either method, and how this translates into a 'U' or 'V' mm correction in the 'Gantry Square parameter boxes'.
    Mar 2017
    1312
    Thank you for your response, you have a point. I will add these to the tutorial.
  1. PlanetCNC TNG software crashing
    By S3eed77z in forum PlanetCNC
    Last Post: 10-07-2020, 07:09 PM
  2. Spindle synchronisation with PlanetCNC TNG
    By PlanetCNC in forum PlanetCNC
    Last Post: 09-08-2019, 08:49 AM
  3. PlanetCNC TNG Slave Set Up
    By Gdog in forum PlanetCNC
    Last Post: 12-28-2018, 01:44 PM
  4. Issues with PlanetCNC TNG
    By nucutza in forum PlanetCNC
    Last Post: 11-19-2017, 10:23 AM
  5. PlanetCNC DIY Controllers and TNG
    By ccandiotes in forum PlanetCNC
    Last Post: 08-01-2017, 10:28 AM
