586,114 active members*
3,245 visitors online*
Results 1 to 3 of 3
    Jun 2006
    59
    My New Low Cost Fixture
    I can upon a problem in our shop. We had a good mill and a couple of vices, but no way to hold plate stock and do perimeter work. I called our local Al supplier and priced out a piece of .750 x 20 x 20 6061. $250!!!! I new I could have my cake and eat it too without thrashing my wallet that hard.
    So I started thinking.
    Why do I need a fixture that thick - for strength and accuracy and to allow for tapped holes to hold down parts.
    Why Al - don't want it to rust, or rust the table to which it is secured.
    My solution was to get a piece of HR mild steel .750 x 20 x 20 and then make a sandwich with some .190 5052 Al that I had acquired cheaply.
    To do this, I deburred all of the edges and bought a couple tubes of JB IndustroWeld. I spread the epoxy out on the plates with a trowel (the toothed tile laying type). I prefer the toothed type so that I could get an even coat. I then put the sandwich - Al on Steel on Al in a vacuum bag and hooked up the pump (rotary vane type) for 6 hours. This nicely squeezed all of the plates together and made one very nice hunk of metal.
    After 48 hours I took the fixture back to the shop and then fly cut both sides. After I finished fly cutting, I bored and counter-bored holes for the bolts in the t-solts and holes for the precision dowel pins (allowing for quick zeroing in when r and r'd from the machine.) When everything was secure, I ran a program and cut coolant channels into the perimeter to keep things flowing nicely.
    Can you say squiiiiished?
    I believe that this fixture has given me everything I could ask for (strength and durability along with resistance to rusting.) I have been using this for 6 mo now and it has been awesome.
    J
    Star SR20RII/Fanuc 18i, DMG CTX310V4/Fanuc 32i, DMG CTX310ECO/Siemens 8400, Mori NV5000/MAPS, Bridgeport 760/Fanuc 18i, Kiamaster 4NEII60/Fanuc 3t;Partmaker, Gibbscam
    Sep 2003
    1469
    Wink Necessity is the mother of Invention
    Good idea!
    Necessity is the mother of Invention, and, as everybody knows, a skinny woman named Poverty is the mother of Necessity.
    Hager
    Jul 2004
    72
    I was interested to see that you have been using it for 6 months. Good for you. My first thought on this design was thermal expansion differences. If your shop took a big swing in temp, would the plate warp? Would it delaminate? But I guess not, good fix.
  1. Building a Fixture...
    By snowJT in forum Mechanical Calculations/Engineering Design
    Last Post: 02-22-2007, 02:25 PM
  2. Q: Fixture plate for x3
    By Deviant in forum Benchtop Machines
    Last Post: 08-31-2006, 02:51 AM
  3. Self centering fixture
    By Hack in forum Mechanical Calculations/Engineering Design
    Last Post: 07-13-2005, 05:09 AM
  4. cylindrical fixture
    By MBG in forum MetalWork Discussion
    Last Post: 06-24-2005, 03:50 PM
  5. material for fixture
    Last Post: 03-12-2005, 08:37 PM
