587,030 active members*
3,800 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > End mill suggestion for special material
    Jul 2022
    10
    I am trying to cut this special material
    Its formed with rubber (red/black) sheet with sponge (purple)
    Total thickness is about 2.0mm and I want to make clean edge cut with CNC
    One more thing to add is that rubber side will always touching the CNC bed side
    I know tangential knife or drag knife will do the job but that's not an option that I have at this moment.
    Please feel free to suggest me anything.
    Jul 2022
    10
    Re: End mill suggestion for special material
    Another close look of material
    In this picture, red part is rubber, and orange part is sponge.
  1. Need material help / suggestion
    By manakawari in forum Material Machining Solutions
    Last Post: 09-01-2016, 06:01 PM
  2. Looking for micro end mill for plastic material
    By Yordanu in forum CNC Tooling
    Last Post: 08-13-2015, 11:32 AM
  3. End mill bit material
    By ALO in forum X3/SX3/G0619/G0463
    Last Post: 04-13-2013, 06:26 AM
  4. Using fly cutter vs End mill end for flatten material
    By Micro Milling in forum MetalWork Discussion
    Last Post: 04-01-2010, 01:07 AM
  5. special ball end mill
    By 98vert in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 12-14-2006, 10:35 PM
