586,067 active members*
5,340 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Need Advice Using Datron m10Pro to machine foil
Results 1 to 1 of 1
    Hi everyone, newb here
    Setup: Datron M10Pro, vacuum table (aluminum), .25 end" mill (helical 31137). Fusion 360 software. Misting some oil like coolant.
    Material: 304 Stainless steel sheets 30"x24" size and .004" thick.
    Speeds + Feeds: 260' SFM, .0017" IPT, Stepover .1". Single pass.
    Objective: Milling various shapes into the foil down by .001" depth. Size of area around 12"x12" square.
    Problem: I've used various speeds and feeds basing them off the data sheet for the end mill and the best results I've hit are pictured above. The Finish is fine, but there is a warping effect on the backside of the sheet that needs to be reduced. I've tried slower and faster settings, multiple passes, a .125" cutter all of which came up with worse results.
    As I have never touched a CNC machine before this, I'm just bashing my head against the machine at this point. So any insight or advice would be greatly welcomed.
  1. Looking for a machine able to cut Aluminum foil
    By MortimerPumpernickel in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-08-2022, 03:58 PM
  2. How can I cut aluminum foil?
    By jmmiller1990 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-23-2021, 09:52 AM
  3. Gold Foil laser HELP!
    By Kezza in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-04-2016, 03:42 AM
  4. Custom Machine Process Definition / DATRON MCR Post
    By tcom-frazzled in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-03-2014, 01:02 PM
  5. Foil layered foam
    By webdude12 in forum Composites, Exotic Metals etc
    Last Post: 10-23-2009, 08:15 PM
