586,058 active members*
4,856 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Should I get AlTiN coating for small cutters in 4140 PH?
    Aug 2012
    279
    Looking at milling with some 3/16 to 1/2" end mills and some profiling with ball end mills. Looks like AlTiN coating is not a lot more. About $11 for carbide 3/16 ball end mill and less than $2 more for coating. Is there any down side to the coating? I am guessing it would not be good for Aluminum and some other materials. Just a hobby shop so would be good to be able to use them on different materials but the 4140 project is significant so other use is not a big factor.
    Nov 2013
    4373
    Re: Should I get AlTiN coating for small cutters in 4140 PH?
    I personally buy coated tools especially for steel and stainless. They also work in just about all materials including aluminum, so I don't see any downside aside from cost.
    AlTiN is a trivalent coating and has affinity with aluminum which is also trivalent and is not therefore recommended despite that it works. The best coating I've ever tried
    for aluminum is either no coating at all OR Titanium-di-Boride. It's a 'greasy as a butchers prick' in aluminum, just the ticket for sticky 3000 series and some of the stickier 5000 series alloys.
    Ferrous metals are tetravalent and AlTiN shows good lubricity in steels.
    I don't know about you but I need all the help I can get to get good tool life and coatings are a part of that.
    Craig
  1. Small CNC cutters
    By Dodgy Geezer in forum DIY CNC Router Table Machines
    Last Post: 10-31-2012, 05:47 PM
  2. programs using small cutters
    By dek in forum RFQ Feedback
    Last Post: 11-02-2011, 08:30 PM
  3. Where to buy 4140 PH steel small quantity
    By DMBGO in forum Want To Buy...Need help!
    Last Post: 07-21-2010, 11:14 PM
  4. machining UHMW with small cutters
    By nagjames in forum MetalWork Discussion
    Last Post: 11-20-2007, 02:53 AM
