586,106 active members*
2,987 visitors online*
    Laser head is getting hot
    Hello,
    I have 130W 500x700mm Chinese laser and laser head is getting hot after 10-15 minutes of cutting.I align laser beam on all 3 mirrors and laser beam hitting center of nozzle.I place tape around holeon head (where laser beam hitting mirror 3) and noticed something like reflection back from mirror 3 and reflection is hitting bottom of the hole.Any sugestion how to solve this because then head is hot laser cant cut well.Laser head have Mo mirror inside.
    Thanks in advance
    Re: Laser head is getting hot
    laser power output percent set
    laser beam path ,
    there are air pipe on laser head to blow smoking etc .
    Quote Originally Posted by allencncrouter View Post
    laser beam path ,
    I cut with 65% power,laser beam hit center of mirror on every position and I use air compressor and solenoid valve to blow smoke
    Nov 2008
    643
    I would change the mirrors out if you can’t find where it’s hitting metal. Be careful working around a beam that’s deflecting somewhere.
  1. Replies: 0
    Last Post: 03-18-2021, 10:03 AM
  2. Hurco KM-3P Head Getting Hot
    By please no smoke in forum HURCO
    Last Post: 09-30-2015, 05:17 AM
  3. Replies: 0
    Last Post: 10-27-2014, 09:44 PM
  4. Hot Head on Mini Mill
    By Me2 in forum Taig Mills / Lathes
    Last Post: 12-26-2009, 04:48 AM
  5. V2XT Head Rebuilt= runs hot & loud
    By v488 in forum Bridgeport / Hardinge Mills
    Last Post: 06-21-2006, 01:35 PM
