586,061 active members*
4,673 visitors online*
    Dec 2008
    41
    Problem with Backlash setting
    Good morning,
    on my new CNC milling machine, I use the Mk3 / 9, TNG and closed loop stepper motors with encoder. Everything works perfectly, except the backlash. My Z axis, for several reasons, is the only one without a ballscrew, so I have to compensate for about 5/100 of backlash. But with that setting I have some problems. In MDI, if I give the command G1Z275F250 it is executed regularly. If after I give the command G1Z0F250, at the end of the path the dro of that axis marks 0.050 (exactly the amount of the set backlash). If, on the other hand, I try to reach the same position with the wireless MPG jog (original), near the Zero, the system begins to search for the position and never stops.
    Dec 2008
    41
    Re: Problem with Backlash setting
    nobody with the same problem?
  1. Looking fo help setting my backlash on my Microkinietics CNC Express
    By PHSS in forum Uncategorised MetalWorking Machines
    Last Post: 11-04-2010, 04:27 PM
  2. Setting the backlash on End block
    By Ferrari2007 in forum DIY CNC Router Table Machines
    Last Post: 12-16-2009, 09:30 PM
  3. Setting Backlash with Turbocnc
    By ecope in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-11-2009, 08:36 PM
  4. is this a backlash problem?
    By xspyke in forum MetalWork Discussion
    Last Post: 04-07-2009, 04:21 AM
  5. Replies: 8
    Last Post: 03-10-2008, 09:35 PM
