586,236 active members*
3,129 visitors online*
    Aug 2011
    999
    Speed Override Default
    I use the speed override function quite often. My projects are all unique and sometimes my choice of speed is not optimal in CAM.
    No problem, I just tweak the speed with the override function from 100% up or down as required for my machine while cutting.
    Unfortunately I forget sometimes to reset this to 100% when finished and the machine may start with 200% speed the next job leaving me to scramble to reduce that before the bit breaks.
    I think it would be better to reset this internal variable to 100% when a new g-code is loaded. The likelihood that the same adjustment is needed for a different job is very small.
    So...I guess this is a feature request for a new version...
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Apr 2022
    12
    Re: Speed Override Default
    I think it's good too
    Aug 2020
    131
    You can just put a friendly reminder in the start script to warn you if your overwrites are not at 100%
    You can have a look at my script for an example
    https://github.com/Klaus-Michael/Pla.../OnStart.gcode
    Apr 2022
    12
    Thanks, this works very well for me.
  1. Default Spindle Speed
    By Richster in forum Mach Mill
    Last Post: 09-16-2019, 10:22 PM
  2. How Read Spindle speed override and Feed rate override?
    By yabhish123 in forum Questions or Problems
    Last Post: 04-16-2018, 06:09 AM
  3. Replies: 0
    Last Post: 04-15-2018, 01:28 PM
  4. Default rapid speed?
    By orion_134 in forum Haas Mills
    Last Post: 12-14-2013, 12:52 AM
  5. Default feed override and manual jog speed settings?
    By InspirationTool in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-22-2007, 11:04 PM
