586,068 active members*
3,876 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Just applied for a job with a company that has
    May 2007
    1003
    one of these machines coming in.
    Anybody have some experience on one? I manual program for the most part, or use MasterCam. This machine will be conversational programming. Never done it, but it didn't look hard to do from what I was shown tonight.
    Can you make money with it on small jobs?
    Edit: You were right. That link sucks. Tried copying it a 2nd time with same results. It is a Mazak Integrex 300-IV ST.
    Do a search for Mazak 9-axis lathe, and it should be the 1st link below the advertisement for Premier Equipment. Least it was for me both times I did the search.
    Feb 2006
    1187
    That weblink SUCKS
    Feb 2005
    750
    Please give the model and make of the machine. The link you gave goes nowhere.
    Halfnutz
    Sep 2007
    217
    No problem with Mastercam
    If the machine is a single turret. The double turret machine is a bit of a bear but not to bad. You will want to make sure they have a good post for the machine. If they do not have a good post for the machine your life is going to be very hard and getting good programs will be a pain. Also you do not use the Conversational side when programing with Mastercam you use the .eia side or g-code side of the machine. You will want to make sure all of the parameters are set-up correctly.
    Feb 2007
    246
    Quote Originally Posted by g-codeguy View Post
    Not on small jobs, you need larger runs or extremely complex parts to make it worth its money.
    Live free or die
  1. Replies: 32
    Last Post: 11-18-2007, 08:18 AM
  2. force applied to table ? is there an easy way to calculate it ?
    By jimtom in forum Mechanical Calculations/Engineering Design
    Last Post: 06-06-2007, 03:36 AM
  3. Old Company name on pendant
    By Conquest1224 in forum DNC Problems and Solutions
    Last Post: 06-02-2007, 01:31 AM
  4. Have you ever applied for patent rights?
    By widgitmaster in forum Community Club House
    Last Post: 08-11-2006, 06:04 PM
  5. Cam- gear motor - force applied to follower?
    By Chris D in forum Mechanical Calculations/Engineering Design
    Last Post: 05-05-2006, 05:41 PM
