586,069 active members*
3,500 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > Trapezoidal thread Tr.48x6
    Jul 2022
    Hi guys,
    Apologies if it's a wrong thread.
    I need help with the above thread type - Tr48x6. Can't find anywhere any specs telling me exactly what's the major & minor diameter size for internal & external thread, or drill size.
    Found a list of standard ISO trapezoidal threads, but Tr48x6 is not there, so I'm assuming it's not a standard thread type.
    Anyone able to help please ?
    Dec 2008
    3109
    Re: Trapezoidal thread Tr.48x6
    Looks like a worm gear...
    Find the next closest with the same pitch.... then add the difference to each value
    ie. Tr46x6.... difference is 2, so add 2 to each min/max spec value.
    Try finding a lower size, as the tolerance values would be tighter
    Remember to look for the 7H class to find the correct min/max values
    Might pay to actually make an external one (easier to measure), so you then check your internal cutting with mote confidence of it being right.
  1. Trapezoidal thread issues
    By chris-bond in forum Mechanical Calculations/Engineering Design
    Last Post: 11-18-2020, 10:26 AM
  2. Trapezoidal Thread cutting
    By gamazard in forum MetalWork Discussion
    Last Post: 12-04-2016, 05:35 PM
  3. mill a trapezoidal thread
    By matzeKlueber in forum Milling
    Last Post: 03-26-2012, 06:33 AM
  4. deburr internal trapezoidal thread
    By fjmoehle in forum Milling
    Last Post: 01-29-2012, 12:18 PM
  5. Trapezoidal thread
    By Reiko in forum HEIDENHAIN -> MillPlus
    Last Post: 06-25-2008, 05:29 PM
