586,062 active members*
4,697 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Preparing lb15ii-m for transport
    Jan 2010
    321
    Hi guys
    We brought a 1997 lb15ii-m that gets picked up next week.
    Normally I would find away to lock the turret from moving during transport to avoid damage.
    With a vdi turret it isn't as easy.
    Question is do you guys usually lock turrets prior to moving or am I being over cautious
    Cheers
    Apr 2009
    1262
    Re: Preparing lb15ii-m for transport
    The machine normally has shipping brackets that prevent the X andZ axes from moving during shipment. The turret is supported from the bottom using an L bracket that bolts to the bottom of the X axis and there is normally a bracket that goes between the Z cross slide and the base. You should be able to spot some holes where the bolts go. Check the electrical cabinet because sometimes they put the shipping brackets in there.
    Experience is what you get just after you needed it.
    Jan 2010
    321
    No brackets.
    Rigged up something with the tail stock. Hope it travels well.
    Cheers
  1. Preparing to buy...need help
    By bigred8080 in forum Avid CNC
    Last Post: 10-27-2016, 11:38 PM
  2. About LB15II
    By cevyil in forum Okuma
    Last Post: 09-27-2013, 09:20 AM
  3. Preparing for the Workshop
    By Jim72 in forum Tormach Personal CNC Mill
    Last Post: 06-29-2012, 12:31 AM
  4. Preparing a mazak VQC for transport
    By working_stiff in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-22-2012, 01:12 AM
  5. OKUMA lb15II-M
    By savasfazer in forum Okuma
    Last Post: 12-20-2009, 11:27 AM
