586,717 active members*
3,201 visitors online*
    Jul 2022
    Problems with controller
    Hello all,
    I have been having issues with my Mk3/4 (4 axis). Every time I turn the spindle on the controller disconnects. Any suggestions?
    Nov 2015
    260
    Re: Problems with controller
    Bad USB cable.
    Mar 2017
    1319
    All symptoms that you described earlier are indicating problems caused by a electromagnetic interference:
    https://en.wikipedia.org/wiki/Electromagnetic_interference
    This occurrence interferes with the USB communication, which as a results drops and communication between controller and PC is terminated.
    You see, electro motors, VFDs etc...are sources of EMI and therefore your wiring and other devices should be properly shielded and filtered. You would need to use shielded cables and use line filters for VFD. Also controller needs to use external power supply for its stable operation.
    http://planet-cnc.com/wp-content/uploads/2016/03/CNCUSBControllerMk3.pdf (page 32)
  1. Stepper Controller Problems
    By CarbonHeater in forum Stepper Motors / Drives
    Last Post: 03-16-2022, 05:55 PM
  2. Problems with Interface Controller
    By AZBBQGrills in forum DynaTorch
    Last Post: 11-03-2010, 11:30 PM
  3. Controller problems...
    By schredder in forum Stepper Motors / Drives
    Last Post: 06-10-2008, 10:53 PM
  4. Controller problems
    By dfurlano in forum Xylotex
    Last Post: 11-12-2007, 03:34 AM
