586,043 active members*
3,600 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Newbie with a Z-Axis problem
    Aug 2022
    Hello! I am having an issue where my Z-Axis is inconsistent in height. I think it may not be retracting up all the way between cuts, leading to a deep plunge on the next one? The video explains more than my words ever could.
    Not sure what the cause is. Any input? Thank you in advance!
    https://youtu.be/cCId23vcBH0?t=15
    Apr 2022
    135
    Re: Newbie with a Z-Axis problem
    Hard to see your Z axis,
    May be add a retracting springs if it’s too heavy.
    I have couple springs on my to compensate the weight, it’s more reliable.
