586,042 active members*
3,850 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > VF-2SS 2011 Alarm 105 at startup?
Page 2 of 2 12
Results 21 to 31 of 31
  1. #21
    Aug 2022
    22
    Re: VF-2SS 2011 Alarm 105 at startup?
    The Z drive amplifier passed the OHM test per the Haas troubleshooting video. And I tested one of the others to compare response. Same.
  2. #22
    Aug 2022
    22
    I tested the motor to amp cable. It checks out.
    The motor test seems kind of odd, but could just be my lack of understanding. The troubleshooting guide says test A.B & C to chassis ground. I don't get a reading on any of the pins in that manner...however...if I take the multi-meter lead on the pin and cross it to the plug housing with the other multi-meter lead to chassis ground I get a reading...however also...if I cross the probe on the pin to the plug housing WITHOUT the other probe grounded, I get no reading...I can't get my head around that just yet.
  3. #23
    Aug 2022
    22
    NVM...that's just ground to ground I think.
  4. #24
    15362
    Quote Originally Posted by No_Joy View Post
    A B &C to chassis Ground there should be no reading, if there was the motor would have a short
    You are doing something wrong if you can get a reading with only one prob connected, or the meter is junk
    Mactec54
  5. #25
    15362
    That does not mean that the drive is ok, you are only testing the high voltage side, and this is normally ok on most of these drives, it the low voltage side that fails most of the time, which if you have no lights on is the low voltage side that has failed.
    Mactec54
  6. #26
    Aug 2022
    22
    So if both lights are out on the amplifier, then the "low voltage side has failed"? Do you know of a link that describes more about this?
  7. #27
    15362
    That is what controls the drive, so if the other drives have lights on and the Z axis does not then the drive has failed, no there is not much information on this part of the drive, or any test, no lights on speaks for itself
    Mactec54
  8. #28
    Aug 2022
    22
    What's really irritating is that the Haas Amplifier troubleshooting test shows this amp to be good.
  9. #29
    15362
    No, it is only showing that the high voltage rectifier is ok, there is a lot more than that to any drive, that's a very basic test
    Mactec54
  10. #30
    Aug 2022
    22
    Do you know what the procedure is for testing the 6 IC under the board at their solder sites, without de-soldering??
  11. #31
    15362
    Did you remove the Board from the metal case
    Mactec54
Page 2 of 2 12
