586,043 active members*
3,906 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Spindax sc 1000 parameter.
    Sep 2017
    Hello from Finlandia.
    My spindle drive have OC alarm ( over current). When i put enable on.
    (the machine worked well, but we moved it other garage( Bad thing ). now spindle not work.)
    I measured motor insulation , coil ohm, resolver etc. all ok.
    My resolver was out of the machine.. must i do resolver phasing?
    Spindle Motor is 5,5kw control techniques
    magnetising current 14A
    slip 50 rpm. 270v /18.5A
    Can anybody help me to check corrent parameters my spindax drive.
    now there is..
    pr 7 = 4
    pr9 = 100
    pr13= 50
    pr 28 = 35 magnetising current
    pr 45 = 47
    regards
    Ahonen VM
    Aug 2015
    32
    Re: Spindax sc 1000 parameter.
    Did you get sorted as those are the normal settings
    Quote Originally Posted by AhWe View Post
    now there is..
    pr 7 = 4
    pr9 = 100
    pr13= 50
    pr 45 = 47
    regards
    Ahonen VM
    Mar 2008
    285
    Ahonen, Robert Varney is one of the the only people I know that could help you with this CT Control with Spindax Drive on an Arrow.
    Contact Fives-Cincinnati and ask for him, he may be able to help you (8595344750) 8am-4:30pm EST USA
    Aug 2015
    32
    Ahonen, the resolver has to be setup correctly if you have removed it and not re installed correctly. Have you got equal voltage on all 3 phases.
  1. CONTROL TECHNIQUES SPINDAX - What can I retrofit it with?
    By Larry Callahan in forum Cincinnati CNC
    Last Post: 06-25-2022, 04:25 AM
  2. Bridgeport VMC 1000-22 Heidenhain parameter TNC370
    By SPSS007 in forum Bridgeport / Hardinge Mills
    Last Post: 08-20-2018, 01:17 PM
  3. Need Mighty Comet 1000 parameter manual
    By 6tee4 in forum Machinery Manuals / Brochures
    Last Post: 10-31-2014, 02:29 PM
  4. Any experts with CT spindax drives?
    By nzben in forum Cincinnati CNC
    Last Post: 03-07-2013, 09:19 AM
  5. Replies: 0
    Last Post: 04-16-2012, 10:36 AM
