586,103 active members*
3,284 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Solidworks file with sketch.
    Sep 2011
    27
    We often send out Solidworks files for other shops to mill blocks for my shop to wire edm.
    In house we apply a 2d sketch on the top surface of the block in Solidworks with sketched circles where and what size we want the wire start hole.
    It works perfect as CamWorks wire will search for those holes and start the profile there.
    We are trying to find a way to export the file and have the sketches go with the solid data? Shops using Fusion 360 can’t seem to see the sketches?
    Any suggestions from the Fusion 360 folks?
    John
    Mar 2008
    683
    Re: Solidworks file with sketch.
    As far as I know you can't do it directly with Fusion. But this plug in will allow it.
    Install the plug in per the instructions at the link...
    https://github.com/kantoku-code/Fusi...urve3D_Doorway
    Step one. Export your IGES file in Solidworks. Use the "Options" button and check "export sketch entities" and "export 3D curves" Then save the file
    Step two. Upload the IGES in to Fusion. Open the file.
    Step Three. In the "Utility" tab open the "Utility" drop down menu to run the "import 3D curves" and select your IGES files again.
    You should now have the curves you wanted.
  1. Rhino Sketch to SolidWorks
    By skippy in forum Rhino 3D
    Last Post: 08-03-2015, 08:15 PM
  2. Rhino Sketch to SolidWorks
    By skippy in forum Solidworks
    Last Post: 08-03-2015, 08:10 PM
  3. Solidworks sketch lines not visible
    By George777 in forum Mastercam
    Last Post: 01-07-2010, 12:04 AM
  4. r\problem with sketch in solidworks 2007
    By brianklein in forum Solidworks
    Last Post: 10-27-2008, 02:57 PM
  5. Solidworks line weights in sketch
    By flyingmike in forum Solidworks
    Last Post: 12-10-2007, 07:51 PM
