586,108 active members*
2,971 visitors online*
    Jul 2007
    21
    Smile FEMCO DURGA 25 E help
    Hello all, needing some help with our Presetter motion. We had to remove to fix a broken wire, and now after replacing presetter the arm slams open and closed.
    We believe we need to bleed hydraulic line to get it to work properly. Does anybody have this knowledge ? Machine is from 1998.
    We will appreciate any help very much.
    927
    Re: FEMCO DURGA 25 E help
    Pre setter "speed" is controlled by the middle valve in the valve stack. Between the Chuck pressure and Tailstock pressure valves. Bottom left side of the front of the machine. On some years, the pre setter valve in not visible without removing the sheet metal. Some it is..
  1. FEMCO Durga 25-E
    By chich2 in forum MetalWork Discussion
    Last Post: 06-22-2020, 04:39 AM
  2. FEMCO HL25E DURGA HELP
    By jimp57 in forum Uncategorised MetalWorking Machines
    Last Post: 06-01-2020, 09:57 AM
  3. Femco Durga 25-E
    By Billet Sean in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2020, 02:30 PM
  4. Femco Durga 25-E Service Tech
    Last Post: 10-17-2010, 07:57 PM
  5. FEMCO DURGA 25E
    By destinationmx in forum Uncategorised MetalWorking Machines
    Last Post: 11-25-2008, 01:00 AM
