586,051 active members*
3,638 visitors online*
Results 1 to 3 of 3
    Jun 2022
    6
    Deckel Maho DMU60 P
    Hello everyone, I have a DMG DMU 60P 1999 year (Millplus V400)
    I have a problem with B-axis rotation, please help me find the answer!
    Error X31 "Endpoint beyond SW limit switch"
    Perhaps I did not write the code correctly, or the problem is something else. If you know how to write code to rotate the B-axis correctly, I will be very glad to see it. maybe
    the problem is inside the machine, I will be glad for any help!
    Sincerely!
    Mar 2016
    325
    Re: Deckel Maho DMU60 P
    Can U show the programm? Looks like u want to move more than machine can.
    Jun 2022
    6
    Hey steryd!
    In general, in my offer to buy the machine is considered a 5-axis simultaneous machining center
    equipped with ITC & chip conveyor. But for some reason I cannot turn the spindle using the code
    in a position between horizontal and vertical.
    The code I tried to rotate the spindle looks like this:
    N1 M55
    N2 G7 B5=30 L1=2 (So it is written in the manual for my machine)
    But after writing this code, I get an X31 error.
    I can turn the spindle to horizontal/vertical position using M53/M54 commands.
    Also in diagnostic mode, I can rotate the spindle to a position between vertical and horizontal,
    and clamp the spindle in these positions.
    Perhaps I am mistaken in the code, or maybe my machine does not really have such a function.
    If you have any advice, I'd be happy to read it.
    In any case, thanks for the help!
  1. deckel maho dmu 50 t
    By gunz in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-24-2021, 01:54 PM
  2. Deckel Maho DMU 50 VL
    By waltteris in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-13-2016, 09:32 PM
  3. Deckel Maho dmc63v
    By Gogycu in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-15-2012, 07:40 PM
  4. Mazak vs Deckel maho
    By Naits in forum Uncategorised MetalWorking Machines
    Last Post: 12-06-2009, 09:25 PM
