586,089 active members*
3,958 visitors online*
IndustryArena Forum > Manufacturing Processes > Grinding > Internal Feature Grinding
    Mar 2009
    76
    Hope the picture attaches here. Curious how you grinding folks would approach grinding the "dished" end feature on this part.
    Is it possible to grind to center or would I need a small void machined on center? The diameter at the intersection with the face is 2.44". We have to grind the feature but are currently not set-up for internal grinding. Is it possible to mount a small ID grinding wheel to a surface grinder or cyclindrical grinder?
    Thx!
    15362
    Re: Internal Feature Grinding
    Quote Originally Posted by chet470 View Post
    Thx!
    Can you CNC machine those radii Etc. you would just machine them to what the finished ground size is, quite often they would be under the ground surface, you would need a CNC Grinder to do it correctly if you had to grind them as per drawing
    Mactec54
    Mar 2009
    76
    Thanks. Unfortunately the material is carbide, so it will have to be ground. I am trying to finish the face at the bottom only, not the radi and angle. We do have a CNC grinder, however, it's a large cylindrical grinder.
    Because it's only a few parts, I'm wondering if I can use a surface grinder with a ID grinding wheel attached, and the part in an electric spin head. I've never attempted to mount a ID wheel to a surface grinder and have no idea if attachments even exist to do this. At this point I'm sort of brainstorming for ideas.
    Jun 2010
    4256
    Could it be that whoever designed this thing had no idea of practical operations? It happens.
    The recess seems to be designed to allow contact only at the rim, which is a stock standard operation. If correct, then any sort of shallow recess would be enough.
    Cheers
    Roger
    15362
    Carbide can be machined you have to use a different grade of carbide, we used to make heading dies and holes and radius were all cut with carbide tooling then Ground and polished
    If you can't do this, then do those parts with a EDM and Grind where needed, I have seen an ID attachment for surface Grinders, but never tried to use one, it would not be the easiest thing to setup and do.
    Mactec54
  1. Internal grinding at Kell Varia-1500mm
    By fh261059 in forum Grinding
    Last Post: 02-08-2022, 05:58 PM
  2. Incorrect internal feature dimensions
    By Xenofon9 in forum DIY CNC Router Table Machines
    Last Post: 10-29-2021, 07:48 PM
  3. CNC Internal Grinding Machine of Centerless Type
    By zhangweilong in forum CNC Machining Centers
    Last Post: 12-01-2014, 03:39 AM
  4. Internal Grinding
    By singist42 in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2013, 04:18 PM
  5. Feature Profile : Internal Corner Types
    By aldepoalo in forum BobCad-Cam
    Last Post: 08-07-2012, 03:19 PM
